 Post subject: Migrate Data from RAID1 to single SATA HDD
PostPosted: December 11th, 2009, 20:15
Hello there,
Could some HDD guru tell me which is the faster and safer way to pass the data (Linux ext3 fs) from a RAID 1 250GB to a new SATA 1TB Disk?...
Im not sure if EASEUS or ACRONIS could do it.
Is it like a simple volume copy?...
I will appreciate any help or tips!!
Thank you!
 Post subject: Re: Migrate Data from RAID1 to single SATA HDD
PostPosted: December 11th, 2009, 22:59
If you are using lvm under mdraid, you can simply move the lv.
Otherwise, use dd.
Users browsing this forum: No registered users and 100 guests
