 Post subject: Hitachi Drive - Constant Clicking Sound
PostPosted: December 8th, 2009, 9:25
Damaged Drive
Hitachi Deskstar
MODEL: HDT725032VLA380
P/N: 0A33663
MLC: BA2364
PCB: 0A53043
BA2178_
Donor Disk
Hitachi Deskstar
P/N: 0A33663
MLC: BA2364
PCB: 0A53043
BA2178_
There was a constant clicking sound on the damaged drive, suspecting head damage, replaced head from donor drive. But still the same. I tried swapping PCB no use also.
Please let me know if you have any idea of what is happening?
Cheers
-Jag
 Post subject: Re: Hitachi Drive - Constant Clicking Sound
PostPosted: December 8th, 2009, 11:49
Any visible media damage?
Data Recovery Ireland
PostPosted: December 8th, 2009, 14:38
No visible platter damage
PostPosted: December 8th, 2009, 14:42
did you check the heads you used are still good?
PostPosted: December 8th, 2009, 14:49
did you test donor before you used it?
PostPosted: December 23rd, 2009, 8:36
Have you tried putting the heads from the original in the donor to cross check whether the heads are really the issue?
PostPosted: December 23rd, 2009, 9:03
sounds like bad headswap or bad donor
Users browsing this forum: No registered users and 312 guests
