December 7th, 2009, 19:40
any ideas re a HDD I have - I've attached audio of the noise it's making - I can't get windows to even recogize it?
- Attachments
- hdd_noise.zip
- hard disk drive noise
- (43.34 KiB) Downloaded 267 times
December 7th, 2009, 20:58
A model number would be handy, but you are facing a seized bearing, or stuck heads surely.
December 7th, 2009, 22:30
thanks - the model was Western Digital 1TB SATAII HDD 16M Cache Green Power
does this help?
December 8th, 2009, 1:03
Yep, you got a stucked motor or the platters are not spinning. DO NOT POWER ON this drive any further if you want your data back. I would say, send it in for the recovery in your area.
December 8th, 2009, 1:15
oh thanks - if the data isn't that important is there something I try to have a crack at fixing? i.e. opening it up/
December 8th, 2009, 4:06
No, there is nothing you can do.
RMA it.
December 8th, 2009, 5:18
RMA?
BTW the drive of course is about 1-2 months just out of warranty. Is it just me or is the disk drive reliability been dropping quite a bit over the last couple of years
December 8th, 2009, 19:31
check the warranty in the WD website.
Normaly is 3 Years warranty.
