 Post subject: How to kill 7200.11 disk using ATA commands
PostPosted: December 11th, 2009, 7:00
Hello friends
I want to give my 1Tb disk to seagate for RMA , which has bad sectors. generally local support is equiped with seagate repair tools so they refurbish it and return same disk.
I want to make disk non detectable so that i will get new disk.Can someone suggest few commands to crash firmware and make it dead forever?
 Post subject: Re: How to kill 7200.11 disk using ATA commands
PostPosted: December 11th, 2009, 7:12
I am sure Seagate will be able to tell difference between generic HDD failure, and malicious damage.
I am sure your HDD will be replaced with new HDD, and not refurbished to you.
PostPosted: December 11th, 2009, 7:59
I dont think seagate has time to check each and every failed disk. Besides its my right to get product replaced rather to get refurbed.
PostPosted: December 11th, 2009, 8:08
you can use a hammer and click it when the disk is spining.
bye bye disk :mrgreen:
or you can drop it when he is spining.
so many ways .... just think .
ZeBong
" Россия еще раз"
PostPosted: December 11th, 2009, 11:18
You will get refurbished disk as RMA one. And it will not be the same drive you sent
PostPosted: December 11th, 2009, 20:41
After careful analysis of posts on this forum, it seems that the following command will eventually cause 7200.11 to die:
READ DMA
PostPosted: December 11th, 2009, 22:27
I see what you did there
PostPosted: December 12th, 2009, 0:54
Hi doomer seagate has given some equipments to there service franschise here in india , that machine can remap bad sectors so instead of replacement they give same disk.
PostPosted: December 12th, 2009, 6:49
Seagate giving away MHDD for free? how nice of them. lol
PostPosted: December 12th, 2009, 14:41
doesn't really sound like RMA process to me
PostPosted: December 14th, 2009, 15:07
Well that does happen when logistics require it. If your living in Uganda and need your drive RMA'd your likely to be the only person in Uganda with a Seagate hard drive :lol: so you will get the same one back... Seagate/Samsung/Toshiba service each main area but smaller countries are self sufficient with a small franchised service cntr IMHO
PostPosted: December 14th, 2009, 15:12
Seagate advisory regarding the 7200.11 Brinks Desktop etc....
seagate.pdf [38.48 KiB]
Downloaded 1312 times
Users browsing this forum: No registered users and 82 guests
