 Post subject: cheap raid5: HD103UJ, ST31000520AS or HDT721010SLA360?
PostPosted: December 17th, 2009, 12:19
I need to build a real cheap 4x1Tb disc R5. No budget in this case for server level discs. Performance not an issue, just reliability. Which would you choose? :?: :?:
THANKS!
 Post subject: Re: cheap raid5: HD103UJ, ST31000520AS or HDT721010SLA360?
PostPosted: December 17th, 2009, 12:25
i'd choose hitachi in this case; only ones i never had trouble with.
Dobre
Murphy was an optimist
PostPosted: December 17th, 2009, 12:26
For the drives I would go with the F1, but using a good raid controller is just as important as selecting the drives if you want the raid array to be somewhat reliable.
PostPosted: December 17th, 2009, 12:36
Thanks for the input, the controller will be the on-board controller on a HP ML 110, in reallity these are soft raid controllers.
Real low budget here. I always say: you can use cheap disks in a redundant raid: just make sure you set up the alert emails because they will fail.. :roll:
Users browsing this forum: No registered users and 280 guests
