Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: Bricked Seagate 7200.11...
PostPosted: December 17th, 2009, 9:20
Hello everybody guru's expert.
I need some information on a seagate 7200.11 (st3500320AS firm : SD15)that I have try to unbrick
one day ..not detected by the bios .. but look that it sounds clearly for me ..
I have search a long time on internet to well understand and try the processus to unbrick my 500 Go drive.
all seems perfect to the command m0,2,2,,,,,22 even if it do not find any user partition and run without error
.. a restart ..
the drive was correclty detected again by bios but no data again ...
So A have read and read and search a long time to find a solution ...
salvation data give m0,6 command so I try ... but same result.
upgrade the firmware to SD1A
and I read a post from gradius2 from msfn forum that 's seems very competent.
he wrote that we could try ...
Try this:
F3 T>m0,1,1,0,0,0,0,22
If no good, try:
F3 T>m0,1,1,2,2,0,0,22
If success, try this again:
F3 T>m0,2,2,0,0,0,0,22
It can takes as slow as 30 to 120 secs to get something on terminal.
Gradius
but the m0,1,1 ... take a long time to execute about 2-3 hours ... with some errors...
while the command running I continue to read all the mega long post and understand was not really a high guru and just copy a solution ...
when I understand that this command seems to erase the sectors .. I stop it ...
so what does this guy say me to do exactly ? m0,1,1 ?
I try many soft and solution .. probably erase sector with hddscan 3.0 from salvation from 900000000 to the end with my bad tests
actually all my sector from 34857 to the end are bad sectors.
is there a way to retreive their status without loss of data ..
any idea ? all lost ?
vincent
 Post subject: Re: Bricked Seagate 7200.11...
PostPosted: December 17th, 2009, 20:44
May be not....
End result of DIY Recovery on these drives
If Salvation gave you that command, you might want to ask their tech to remote in on your system and see if they can help you recover it!!!
PostPosted: December 17th, 2009, 21:11
Don't worry, SD suxs, but their tech support is great :D
PostPosted: December 18th, 2009, 5:39
salvation did not give me .. I only found a page from their site that give this command on the unbrick process for seagate busy mode .
I suppose yep that their tech is like you a guru ...
ok ok...
I understand now that professionals do not help other people that do not have the money to pay for a recover.
a cruel world and business is preserved ...
thks for you reading hddmania and headcrash
PostPosted: December 18th, 2009, 5:58
sounds like you will need to remap bad sector in order for translator to be rebuilt. You should send this to someone in the know.
PostPosted: December 18th, 2009, 6:01
vincent
I think you may have just lost your data....
PostPosted: December 18th, 2009, 6:04
more evidence that DIY is the way to go :lol:
PostPosted: December 18th, 2009, 6:27
You seem awfully happy the guy lost all his data.
PostPosted: December 18th, 2009, 6:28
well what can I say, It's Christmas. :P
Maybe his misfortune will prevent others from doing the same.
PostPosted: December 18th, 2009, 6:34
Nobody is happy to see anybody lose sentimental and important information, but it has been said time and time again that DIY Data Recovery hardly ever has a happy ending. We are often criticised for 'not helping' and not revealing secrets, but this case is the perfect justification: the right commands, in the wrong hands = data loss. It is as simple as that, and I hope that this will highlight just how easy it is to make a mistake without the right knowledge
PostPosted: December 18th, 2009, 6:35
mybe so, but you are still happy for someone misfortune.
PostPosted: December 18th, 2009, 6:36
i know you are right, and i know you arnt happy he lost his data but hddspaz is.
PostPosted: December 18th, 2009, 6:39
I'm always happy, I have my health, wealth and my data :lol: (sorry couldn't help it). Why shouldn't I be happy? The guy has done a lot of reading, he should have known the risks. I have no sympathy. my sympathy is reserved for deserving causes.
PostPosted: December 18th, 2009, 6:47
I have a question to original poster, he says Salvation data suggest trying m0,6 command, does this mean he is SD customer, and this drive potentially is not his own but a clients?
As much as SD are criticised, they are more reliable than a post at MSFN topic boards.
PostPosted: December 18th, 2009, 6:49
Sorry for your lost, i think this topic should be placed as sticky to remind others of DIY risks. RIP data..... :?
PostPosted: December 18th, 2009, 7:10
Ha Ha!!! Loser! :evil:
The last I heard of God he was worshiping me
PostPosted: December 18th, 2009, 7:13
That is your problem, thats something that happend to somone ELSE, not you.
you lack ability to feel anything for people other than yourself.
PostPosted: December 18th, 2009, 8:11
Yes I quite agree, just be happy your not married to me :lol:
PostPosted: December 18th, 2009, 8:22
Yes and he also pointed out the risks........
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8
User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs
User Partition Format Successful - Elapsed Time 0 mins 05 secs
If you didn't get the msg above, then you skipped something important, and turning off your drive now will render an unreadable drive, so be careful.
ONLY after the message like above you can turn off everything.
I think he could not have made it any clearer!
PostPosted: December 18th, 2009, 10:01
yes I have done exactly perfectly what all the procedure on the net say to unbrick an 7200.11...
I 'am sure to have done perfectly what the proc say to do ... I have read many many time before doing ...
and yes I also know that diy recover is not the best way to get back data ..
and no I am not client of SD... If financialy I could, it would be a pleasure ...
when you lost your job from several month the first choice is not to pay to recover the 0-12 month of your daughter .......................
Now, I only want to know if with all my bad command my drive is deleted definitly ?
could I do a low level format to get back a new 500Gb drive for free ?
Users browsing this forum: Google [Bot] and 269 guests
