 Post subject: Seagate 7200.7 ST380011A powers off and on by itself
PostPosted: December 13th, 2009, 14:45
Sorry for my English.
My ST380011A (firmware 3.04) is 5.5 years old and Seatools say it has been on 16000 hours.
In the last 10 days i've got a problem. The hard disk powers off by itself and on again in few seconds. Sometimes it does it just one time and sometimes it does it again and again. Energy saving options are off, both in Windows and in BIOS.
It makes the same noise (a little "click") than when I turn on my computer. It's NOT the same noise when it gets idle and then on again cause of the energy saving.
All Seatools test are ok (smart, short and long DST).
My question: it could be a software problem? I mean, is it possible to power down a drive by software? If it's not possible then it's a hardware problem for sure.
 Post subject: Re: Seagate 7200.7 ST380011A powers off and on by itself
PostPosted: December 13th, 2009, 15:13
Backup everything while you can!!! The drive is more than likely in the last breath...
PostPosted: December 14th, 2009, 5:24
hddmania is absolutely right! Our compassions to your drive. And search for similar threads here - you will find advises what to do.
PostPosted: December 15th, 2009, 5:59
Thank you. I had know 3 computers with Seagate ST380011A. Two of them absolutely failed (lost all data) and mine, which is in the "last breath".
PostPosted: December 28th, 2009, 6:43
You can try to find someone from Spain to help you if there's any chance...
Users browsing this forum: No registered users and 151 guests
