7200.11 1TB - PLATTER SWAP - China Thailand
November 10th, 2009, 12:08
Hi to all,
Need to exchange the platter in a Seagate 1Tb disk, that have the motor stuck.
D - THAILAND
P - CHINA
i need to match the rotor latch and frequency ?, or i do not have to take car about that ?
ZeBong
Re: 7200.11 1TB - PLATTER SWAP - China Thailand
November 10th, 2009, 19:21
That's a good question.
I don't know, but my guess would be that since you move the platters and you don't have a site code match you will also need to move the HSA. Maybe someone else can clarify things with more certainty in regards to motor match.
November 10th, 2009, 19:37
you don't need to match it
Brinks base also works fine for Moose drives and vise versa
November 10th, 2009, 19:40
Hi, thanks to all.
will try it.
November 11th, 2009, 13:39
Please let us know how it goes.
-maux
December 30th, 2009, 18:34
Hi to all,
I have made the platter swap from Brinks base to Moose base.
But the heads from the Donor had problem so i order a new disk with the site code matching, but i get a refusrbish disk, had change the heads notice that the PREAMP is different and i can not get ID.
Anyone was get sucess with this ?
December 31st, 2009, 3:43
Good Day
i also had same problem i swapped Platters it shows Head Problem waiting for head.
