 Post subject: Spinrite OMG
PostPosted: March 23rd, 2010, 11:53
Hi guys im very new to data recovery but ive been in IT for eons.... one of my co-workers ran spinrite on a clients notebook which hard drive was failing.... the hard drive now seems to work stellar but he cant find the outlook.pst file :S is there any way to reverse spinrite or get back this outlook.pst file?
 Post subject: Re: Spinrite OMG
PostPosted: March 23rd, 2010, 18:07
:lol:
PostPosted: March 23rd, 2010, 18:25
Assuming there is no surface problems give it a once over with r-studio (scan the disk) you may get lucky and find your file. Dont do this if the drive is clicking!
:Leigh
DataWreck Data Recovery Services
www.DataWreck.co.uk
PostPosted: March 23rd, 2010, 20:58
Datawreck
i think there was a surface problem, it had some bad sectors if that makes a difference... :(
PostPosted: March 24th, 2010, 4:14
Hello darkosski, Please read the spinrite wikipedia page as it gives good advice to amatuer data recovery technicians.
The heading 'Alternatives' may give good insight.
http://en.wikipedia.org/wiki/SpinRite
Zero Alpha: zeroalpha.com.au
PostPosted: March 24th, 2010, 4:20
Maybe the bads that spinrite has "solved".... contained data.
Results of the DIY. What now ?
PostPosted: March 25th, 2010, 10:51
thanks for the info guys.... and gals
PostPosted: March 25th, 2010, 14:34
That is why the Spinrite manual suggests backing up the data before running the program. Once a sector has been remapped, any data that it left behind is gone. You might get lucky with a full scan of the drive with R-Studio, but I would suggest mirroring the drive first.
As I tell my clients...before Spinrite is run...usually less than $500...after Spinrite is run...likely more than $1000, if recoverable at all.
PostPosted: March 25th, 2010, 17:53
I Agree 100% with luke(lcoughey).Image the drive first. Other than R-studio, GetDataBack by Runtime can stitch files back to the file system quite well. This is assuming you don't have software like DE at your disposal. Even then...
Leigh
www.DataWreck.co.uk
PostPosted: March 25th, 2010, 20:41
this is why you do a image of the drive first then use spinrite
i dont really use this for any recovery needs as i dont see how it can recovery in the help of your data
your find out that the data was on the bad sector
so it be bye bye data forever.
Users browsing this forum: Google [Bot], michael chiklis and 83 guests
