What is the position of the heads when sata cable isnt in?
January 10th, 2010, 16:34
If i connect the power and not the sata what do the heads do?
do they move at all?
only at the start?
do they stay parked until sata is in?
Re: What is the position of the heads when sata cable isnt in?
January 10th, 2010, 17:40
As you have described does the motor spin up?
Depending on the drive make and model, the jumper position might determine if the drive will spin up with or without a signal from the motherboard.
January 10th, 2010, 19:38
Typically the drive will still init normally but I have seen some Hitachi laptop drives that don't do anything until SATA is plugged.
