Iomega Star Center500GB
January 3rd, 2010, 10:23
Good Day
i have a problem with Iomega Star Center Ext HDD 2x250 GB seagate IDE in it is detecting in network and showing 0GB capacity Thanks for any Response.
Re: Iomega Star Center500GB
January 3rd, 2010, 11:12
You must connect disk directly to the sata/pata cable. What model of disk do you have?
January 4th, 2010, 1:28
Good Day
Thanks for reply it is ST3250823A seagate IDE 250GB i connect directly to PC checked with R studio software it shows 4 partitions inside of Each Drive do u think it is Raid0 ??
January 4th, 2010, 2:55
Good day
check this link for more Details about Drive https://iomega-eu-en.custhelp.com/cgi-b ... d=1snC77Rj
January 4th, 2010, 3:47
Have You access to data? Is data ok, or maybe picture is striped?
If it is RAID 1 - you have exactly copy on both of the disks.
If it is RAID 1 - the best way you should use DMDE for image the disks, and then try to rebuild the RAID.
January 4th, 2010, 4:11
Arvika but it has RAID0 i checked with Runtime Raid reconstructor trying to copy disk in new Drive.
January 4th, 2010, 7:47
Sorry, in second line should be:
If it is RAID 0 - the best way you should use DMDE for image the disks, and then try to rebuild the RAID.
Addition:
DMDE have a nice function to build virtual RAID 0 :)
January 9th, 2010, 5:14
Good day
i used Run Time Raid reconstrcutor i configure Raid0 and copied in 1 TB External HDD it has Xfs partition i Run UFs explorer for Data Recovery it shows some Data but not with Structure most of the data is corrupted if any one face same Problem please share u r Experiance this is Drive Model check link https://iomega-eu-en.custhelp.com/cgi-b ... d=YZgP8yRj
January 12th, 2010, 10:43
on one face same problem like this????
January 12th, 2010, 11:59
you have to determine raid starting sector, block size and disk order. then run your ufs explorer.
