 Post subject: ST31000340AS No terminal?
PostPosted: January 13th, 2010, 23:25
Hello gurus. I freed a jammed spindle on this drive and now get it to spin up slowly with noise. But I don't get any terminal output and it just does a couple of light clicks every 10-20seconds and stays busy. Is platter swap necessary?
Zero Alpha: zeroalpha.com.au
 Post subject: Re: ST31000340AS No terminal?
PostPosted: January 14th, 2010, 0:21
Most likely. If shaft is bent there is no way drive can gain enough speed to get it into ready state. In old good times it was possibly to loose bearings just by manually turning platters forward and back. No more :(
Good Luck
http://www.datarecovery.net
PostPosted: January 14th, 2010, 0:28
Of course yes , and check both and the heads...
XRONIS
T3 Professional Data Recovery
http://www.t3-recovery.com
PostPosted: January 14th, 2010, 2:25
cheers ... these are very tough jobs.
Users browsing this forum: Google [Bot] and 201 guests
