 Post subject: cutting off the beginning of a hhdrive?
PostPosted: January 15th, 2010, 17:38
Is there some way to cut off the beginning of a hard drive surface?
Most of softwares can only cut off the end of a hard drive.
My hard disk has bad sectors at beginning. I have repaired these sectors, perforemed low level format, etc but after some days , it crashes again xp.
I thinks the only solution would be " to cut off the beginning of a hard drive" , approximately 4gb
Thanks in advance
 Post subject: Re: cutting off the beginning of a hhdrive?
PostPosted: January 15th, 2010, 17:45
Just get the data off if you can, and replace the drive
PostPosted: January 16th, 2010, 13:22
For cutting in the beginning you need special tools and deep knowledge of SA , You can leave the area making partition in such a way .
Users browsing this forum: Google [Bot] and 203 guests
