 Post subject: ST 35 00 418 AS - SEAGATE 7200.12
PostPosted: January 22nd, 2010, 9:15
Hi to all,
Have this disk when give power it clicks.
Change heads with the same pre amp ( and try to match the Data code almost as possible)
Patient : 09417 corresponds to 2009 April 17th
Donor :
BR2-T TIAA-B
But it happen the same it clicks.
Put the heads back in the donor and they work. the donor works 100% ok.
The heads off the patient into the donor, dont clik get DRD DSC but no size ( INFO FROM THE PCB).
Anyone have an ideya what i have to match for the heads change in seagate 7200.12
ZeBong
" Россия еще раз"
Users browsing this forum: Majestic-12 [Bot] and 62 guests
