 Post subject: Looks like Solid-State drives will be keeping us busy.
PostPosted: January 25th, 2010, 16:50
Got in a 160GB SSD with a blown diode and was able to recover. Same for a 64GB. Then, I just got in a 256GB one that is completely dead as well. It's a Crucial drive, and they apparently are having a ton of problems with these just dying out. I haven't found the dead link in this particular drive yet. Still working on it. Anyone else starting to get in SS drives?
 Post subject: Re: Looks like Solid-State drives will be keeping us busy.
PostPosted: January 26th, 2010, 2:53
yep they are failing bigtime these new solid state drive
infact they fail more then the normal hard drives.
parts over heat and bang goes the diodes
PostPosted: January 26th, 2010, 5:15
What symptoms do you have with the blown diodes? So far I have seen a 32GB SSD Expresscard, shows ID but no access to data, recovered this by removing NANDs - it has simple UT163 controller, 2 Samsung SSD drives, 64GB and 128GB, both fail to ID but customer requested these back before I could work with them, and a 128GB Kingston SSD. This shows ID but no access. Will work on this one today or tomorrow.
PostPosted: January 26th, 2010, 9:32
This would be a good topic for closed discussion
PostPosted: January 26th, 2010, 12:26
The diode issues seem to result in no access to the drive at all, and I mean no drive ID or anything. On the first couple of cases I got in, I just sat down with my multi-meter and tested each component. My customer on this Crucial 256GB drive is getting impatient, so I may not have time to figure out exactly what the problem is there. Same thing though, drive is not recognized. It will recognize when I flip the switch to flash the firmware, but even then it's not recognizing properly, just the raw id from the ROM.
PostPosted: January 26th, 2010, 12:47
Agreed :)
https://www.mjm.co.uk/
Users browsing this forum: WebClaw and 57 guests
