I keep ending up with multiple drive failures on my server. Configured -RAID 6, 1 TB WD disks
Array controller ( P800 ), hdd - all updated to latest fw versions.
The adu log says
Last Failure Reason: 0x0E (Aborted command)
Looks like the drives were failed because the drive aborted a command 'n' times. This is why the failure reason is 0x0E .
ALso hooked up a serial cable to the array controller and this is what the trace point says
Fail Device: D010 physical_req 11fd48 - reason code eh
Can anyone shed some more light on this???
Secondly,Is there any way I can get some low level info on these failures from /proc/... or some else from the kernel level?
Adu report attached
Cheers
David
- Attachments
adureport.txt
- Adu report attached
- (105.69 KiB) Downloaded 275 times
