 Post subject: Seagate 7200.12 ST3500418AS fail to start
PostPosted: December 26th, 2009, 16:39
Hi all,
I hope somebody can point me in the right direction. I have a ST3500418AS that worked for about 9 months, and died suddenly after a simple reboot. Not sure what happened, but I didn't abuse the disk in any way.
I tested it with Seatools, and this is the result:
Model: ST3500410AS
Firmware Revision: CC34
SMART - Pass 12/25/2009 10:23:10 PM
Short DST - Started 12/25/2009 10:23:17 PM
Short DST - FAIL 12/25/2009 10:23:47 PM
SeaTools Test Code: AEA8DBE0
Attached is the sound it makes on startup (I amplified it a lot).
Thanks!
ST3500418AS.zip [214.58 KiB]
Downloaded 624 times
 Post subject: Re: Seagate 7200.12 ST3500418AS fail to start
PostPosted: December 30th, 2009, 19:03
Anybody?
I forgot to mention, BIOS recognizes it after a long delay with HDD led on, but with 0GB size. Could this be a firmware problem, like on the 7200.11 models?
Thanks.
PostPosted: December 30th, 2009, 19:23
That info is from the PCB.
is the data important ?
ZeBong
" Россия еще раз"
PostPosted: December 31st, 2009, 3:10
I agree with Zebong it is Firmware Problem.
PostPosted: December 31st, 2009, 7:32
I'd prefer no to send the disk, as it contains my personal data, pictures, etc. OTOH, I have backup.
My question is more about what happened, could it be a firmware fault or (listen to the audio sample) is it a motor failing.
PostPosted: January 29th, 2010, 14:03
Finally I RMA'd the disk and they send me a refurbished one, but with new firmware: CC37
However, I'd still like to know what was wrong (listen to the audio sample, please).
Thanks.
PostPosted: February 5th, 2010, 5:26
similar failure like 7200.11, it belongs to firmware failure and can fix.
Users browsing this forum: Google [Bot] and 73 guests
