 Post subject: st3160022ace firmware
PostPosted: February 8th, 2010, 13:30
I have a st3160022ace pulled from a set top dvr box. it seems to firmware limited to 20gb. is there a flash firmware file to open up the 160gb the drive should have?
 Post subject: Re: st3160022ace firmware
PostPosted: February 8th, 2010, 14:28
Sure its not HPA ?
https://www.mjm.co.uk/
PostPosted: February 8th, 2010, 20:06
After reading many of the other posts, you are probably right , it is most likely an hpa issue. i will try to use the hdd capacity restore tool from this website.
thanks for the quick response to my newbie question.
Users browsing this forum: Google [Bot] and 48 guests
