 Post subject: Seagate 7200.11 Firmware issue: HP24 Firmware
PostPosted: February 10th, 2010, 4:30
My hard drive stopped working a month ago, and I finally get the hyperterminal working, but after first two command:
F3 t>/2
F3 t>z
it shows following and I can not move any further,
LED:000000CC FAddr:00259E1D
I have tried to seach on the web for the code but seems nobody ever had the same code before.
Any one out there could help ??
 Post subject: Re: Seagate 7200.11 Firmware issue: HP24 Firmware
PostPosted: February 10th, 2010, 4:37
There is something wrong with that terminal input and response.
If you want your data, I advise you to stop what your are doing and consult a pro, before you brick the drive.
If you don't care for the data, then carry on playing by all means.
PostPosted: February 10th, 2010, 5:08
F3 t>/2
F3 t>z
WARNING: Pay attention to uppercase and lowercase when typing terminal commands.
Here are repair procedures for Seagate 7200.11 drives:
http://sites.google.com/site/seagatefix/
http://www.msfn.org/board/index.php?showtopic=128807
Tutorial with photos:
http://www.overclock.net/hard-drives-st ... -pics.html
Pinout of Nokia CA-42 cable's Pop-port connector (use pins 6,7,8):
http://pinouts.ru/CellularPhones-Nokia/ ... nout.shtml
See the following technical bulletin:
http://atulchitnis.net/files/seagate.pdf
Seagate were at one time offering free data recovery services to those customers whose drives were affected by the bug. This may still be the case.
PostPosted: February 10th, 2010, 5:13
I may be wrong - I think that the free recovery was for hard disks that got bricked when the firmware update was applied to certain drives - I think it was only the 500 Gb version of 7200.11 that the firmware update actually made worse.. So seagate offered free data recovery on these drives - is that right Doomer ?
https://www.mjm.co.uk/
PostPosted: February 10th, 2010, 5:26
Yes, you are wrong. :-)
Free recovery also applied to drives bricked by the original bug, not just the buggy bugfix.
The policy is well documented in Seagate's forums and/or knowledge base.
PostPosted: February 10th, 2010, 7:54
AFAIK, the free recovery doesn't apply to OEM drives, which I believe make up 90%+ of the affected drives out there.
PostPosted: February 10th, 2010, 8:10
which is good for us. :mrgreen:
PostPosted: February 10th, 2010, 11:11
Thanks fzabkar
It is case sensitive. I now got my hard drive life back.
:D :D :D
