 Post subject: Seagate Barracuda 7200.11 disk will not spin up
PostPosted: February 13th, 2010, 12:21
I own a Seagate Barracuda 7200.11 disk, 1,5TB, firmware SD37. I bought it in april 2009, it have been used for backup.
The disk have only been running for 100-200 hours.
I´ve seen some times, that there was a strange clicksound from the disk, during that it was not possible to access the disk. I removed the disk from my computer, stopped and started it again, at it worked ok. The dealer wouldn´t return it, he tested it, and claimed that it was ok. But this error was intermittent.
Now there is a much more serious error: The motor will not start at all. There is a typical startup sound from the disk, it sounds surely like the spindle is locked in some way.
Last time I used the disk it was working ok. I haven´t dropped it on the floor etc.
I´ve bought a new disk, and changed the circuit board. It didn´t help at all. Any sugestions on how to make the spindle start up?
 Post subject: Re: Seagate Barracuda 7200.11 disk will not spin up
PostPosted: February 13th, 2010, 12:34
There is no other way, but to take it to Data Recovery company.
www.datarecoveryne.com
PostPosted: February 13th, 2010, 13:13
PCB's are UNIQUE on these drives.
What happened when you put the other PCB on? Did it spin up and click, or just make the "trying to spin up" noises?
Users browsing this forum: Google [Bot] and 90 guests
