 Post subject: HTS541060G9AT00 identical donor, but shows errors with pcb
PostPosted: February 15th, 2010, 22:20
I have an identical donor Hitachi Travelstar 2.5 Model: HTS541060G9AT00 P/N:0A25433 MLC: DA1175
JUL-05 Made in Thailand, but the PCB board on the original says made in malaysia and the donor says china. I put the donor drive to sleep, hot swap the pcb and when I try to image it with the Deepspar I get a green box with an "A" in the middle. I think that the pcb board for the donor is not close enough and these donors are not easy to come by. Does it look like a head issue or pcb not clos enough on the donor...?
 Post subject: Re: HTS541060G9AT00 identical donor, but shows errors with pcb
PostPosted: February 15th, 2010, 22:49
For these drives u need to swap NVRAM as well... provided that donor PCB ROM version matches the patient.
PostPosted: February 15th, 2010, 22:55
post images of your both PCB both side here.
data recovery service[/b]
PostPosted: February 16th, 2010, 14:39
You cannot swap Hitachi.
PostPosted: February 17th, 2010, 11:17
Here is an image of both drives..
File comment: Here is the image of the 2 drives, the one that has writing is the original drive...
PostPosted: February 17th, 2010, 18:58
Can we see the component sides of both PCBs?
PostPosted: February 18th, 2010, 15:50
I meant you cannot hot-swap Hitachi.
PostPosted: February 19th, 2010, 10:37
The one on the left is the original pcb and the donor is on the right side..
PostPosted: February 19th, 2010, 19:04
And u cannot 'cold-swap' either :)
I told u the reason, there's nothing more that can be said about the matter.
I do not have a spoon with me right now.
PostPosted: February 19th, 2010, 20:02
I'm not a DR guy, but I should be able to identify the ROM and NVRAM if you upload clear, detailed photos of the PCBs. If the other side has any components, please photograph it as well.
BTW, just be sure, does the drive spin up with the original PCB?
Users browsing this forum: No registered users and 65 guests
