 Post subject: SAMSUNG hd753lj with fried ROM -Please help me to solve it
PostPosted: February 21st, 2010, 13:38
Hi everybody! This is my first post and I would like to share a solution to recover my PCB and data soterd on my hdd.
The TVS Diode is short and I remove it a long time before, but now I have a problem on my drive as you can see on pics posted below
 Post subject: Re: SAMSUNG hd753lj with fried ROM -Please help me to solve it
PostPosted: February 21st, 2010, 14:13
That's not a ROM
PostPosted: February 21st, 2010, 14:26
Post full picture of your pcb then we will tell you where ROM is .
PostPosted: February 21st, 2010, 15:43
This is a good example of why you never run the drive again after recovery. Especially not without the TVS!
PostPosted: February 21st, 2010, 17:45
Yes, and I would either junk the psu or the power control circuit to the drive. Otherwise the replacement will go up in a similar puff of smoke.
PostPosted: February 21st, 2010, 20:21
OK, I'm not shure it was a ROM chip. I think that its an voltage regulator.
What chip can I replace for the fried one ? It was ST... (model was fried)
PostPosted: February 21st, 2010, 20:41
I don't think that PSU was the guilty. It's good coolermaster 1000W etc. It think that Thermaltake's BlacX doc station do a half of dirty job beside capacitor I put in place of dead TVS as you can see in PCB's pics
PostPosted: February 21st, 2010, 23:04
this hard to done by yourself.
data recovery service[/b]
PostPosted: February 21st, 2010, 23:58
That could be a MOSFET, or a switchmode regulator that incorporates a MOSFET.
The flywheel diode is a B240 Schottky.
B240, 2.0A, 40V, Diodes Inc, SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER:
http://www.diodes.com/datasheets/ds13004.pdf
The mark on the chip looks like a dab of paint or liquid paper. I don't think I've ever seen a chip fail that way.
That particular regulator appears to supply the negative voltage for the preamp.
What was the failure symptom?
PostPosted: February 22nd, 2010, 9:58
It stopped to be detected by BIOS and when I remove it this chip on PCB was fried.
I can do repair on this PCB. I will put my progress here and all help will be welcomed
PostPosted: February 22nd, 2010, 15:00
Here is a datasheet, with application circuits, for a typical motor controller chip:
http://www.datasheetarchive.com/pdf-dat ... /28826.pdf
I would check whether the preamp is shorted. This could take out the negative voltage regulator. Follow the bottom end of the 1R2 coil to the 20-pin preamp connector. I believe that should be the negative rail. The ground should be easy to find.
This article should help you identify the components:
http://hddscan.com/doc/HDD_from_inside.html
PostPosted: February 22nd, 2010, 16:09
See this photo:
download/file.php?id=1386&mode=view
The mystery part is an STJ009 MOSFET.
STJ009, 30V, 5A, P-channel Trench MOSFET, AUK Corp:
http://www.lintry.com.cn/spec/17/STJ009.pdf
http://www.datasheetarchive.com/pdf-dat ... -24387.pdf
Users browsing this forum: No registered users and 154 guests
