 Post subject: WD5000AAJS-00YFA0 - Data Recovery Possible?
PostPosted: February 24th, 2010, 9:52
I have a WD5000AAJS that was being used as a system drive and for some data storage that went bad on me.
Symptoms: System started acting up, randomly freezing. Removed drive, drive was HOT. Let cool, booted, then system would freeze again. System will not boot now.
The drive will spin up, make 5 "seeking" noises successively then a whirr, then spins down and back up to a constant velocity and stays that way. These aren't hard "clicks". I've had a drive that failed that CLICKED, this sounds like HDD seeking noises.
Is this likely PCB? Physical damage? Both?
If so, and there's someone reputable on these forums in the connecticut/new england/Tri State area that can help I'd appreciate any information/quotes, etc. I dont' expect to be able to DIY it, I understand the ROM is embedded and requires professional intervention to rebuild.
Thanks in advance.
 Post subject: Re: WD5000AAJS-00YFA0 - Data Recovery Possible?
PostPosted: February 24th, 2010, 10:04
It is my experience that the first thing to check with these drives is the PCB. That being said, the second most common problem is the heads. So, I regret to say that this is something that will need to be assessed by a data recovery professional.
The only lab that I know of in your area is Vantage Tech (www.vantagetech.com). Talk to Kevin, he should be able to help you out.
Good luck!
PostPosted: February 24th, 2010, 10:38
Thanks in advance.
You can bring your drive to us for diagnostics.
We'll diagnose it in front of you.
Check your PM for details.
www.datarecoveryne.com
PostPosted: February 24th, 2010, 10:49
harddrivespecialist should be able to take care of it for you.
Users browsing this forum: Google [Bot] and 55 guests
