 Post subject: USB driver hangs
PostPosted: March 4th, 2010, 14:06
Hi guys!
I got myself a Toshiba MK3006GAL via eBay, but all programs insist it's only a 16 GB drive instead of 30 GB. I tried to access it with MHDD, but as I only have a netbook, I had to attach the device - as well as the CD-ROM - via USB.
I used the Magic Boot Disc, but the Panasonic USB driver always hangs. It tells me
... Initializing Host Controller 1/5 ...
and that's it. :-( Anybody got a suggestion what I could do here?
Ben
 Post subject: Re: USB driver hangs
PostPosted: March 5th, 2010, 7:34
Does this drive support HPA ?
https://www.mjm.co.uk/
PostPosted: March 5th, 2010, 7:43
Well, I've no idea. That's what I wanted to find out. But in the end, it's a normal 1,8" IDE drive, so it should, I guess?
Ben
PostPosted: March 5th, 2010, 11:06
Can you install the toshiba to your netbook? I am sure you can boot from USB memory sticks on these netbooks also, maybe you can run MHDD from a USB stick with your Toshiba installed to the netbook?
MHDD will tell you if HPA is active.
PostPosted: March 5th, 2010, 12:49
I guess I could, but then I'd need a SATA-to-1.8"-PATA adapter. I ordered a 3.5" to 1.8" IDE adapter instead, so I can fit the drive in my normal desktop computer. Once I get home, that is, which won't be any sooner than middle of April. I hate to wait! ;-(
Ben
PostPosted: March 5th, 2010, 14:23
Hiren's boot CD (version 9.0 or better) has a better DOS USB driver. Choose more->DOS->DOS (USB support). Try option 1, and check "newer computer" setting in the USB driver screen. The old version that you have only supported USB 1.0 and 1.1, the newer version also supports USB 2.0.
http://www.youtube.com/user/TerraformingMaster
Users browsing this forum: Bing [Bot] and 105 guests
