 Post subject: HITACHI HTS541080G9AT00 / 80GB Please Help
PostPosted: February 28th, 2010, 15:52
Dear Gurus,
Reason is still unknown why my laptop finally showed "operation system not found" message
also after having some blue and black screens during the week.
What I did is:
Removed the HD from the laptop. Plugged to the Smart USB interface and the interface to the desktop PC.
1.Desktop PC assigned a G: drive to the disc and showed no data when its explored.
2.By right click the Disk showed that it is full and RAW as a file system.
3.I have tried: Power Data Recovery, it has found the device but no data
Stellar Phoenix Windows Data Recovery showed , not valid logical drive or critical data structure are badly corrupted for this drive.. Getdataback could not find anything..
So what can I do? Shall I do format and do format recovery? I am not sure.
Could you Please help me about this? This cannot be that bad. I mean everything is just gone!!
 Post subject: Re: HITACHI HTS541080G9AT00 / 80GB Please Help
PostPosted: March 1st, 2010, 9:31
Good Day
if u r Data is Most Important then give drive to Data Recovery Company Near to u r place if not that much important try with R-Studio software this Model Drive having Bad Sectors Problem check any Bad Sectors recovery softwares.
PostPosted: March 1st, 2010, 15:19
Well a quick check with R-studio might be helpful but really some basic diagnostic checks need to be made. You could use MHDD though as you have a usb interface at your disposal you could instead use Victoria for windows.
Another thing, rather than run every known recovery utility on your drive it would be a good idea to make a sector level image of the problem drive. Either to a 2nd spare drive or as an image file. That way you can work on the data without causing any damage. Do the diagnostics 1st!
PostPosted: March 1st, 2010, 15:47
Please excuse my ignorance mr itconcepts, mr dick,
But what is MHDD?
And may I do this basic diagnostic checks with R-Studio?
Thank you very much.
PostPosted: March 1st, 2010, 16:32
My screen shot from the r-studio program is just like on the screenshot.(attached)
The one I want to recover is HTS54....
There is no recover delete or scan option is available when I right click.
Unfortunately I am not a good tuneman. But I am sure you can help me.please.
File comment: screenshot
PostPosted: March 2nd, 2010, 1:26
Hi
r u following wrong procedure i think select u r Drive Right click select Scan Try Simple scan it is faster procedure if u can't find Proper Data Try again with Detailed scan u will get Results.
PostPosted: March 2nd, 2010, 14:46
hello
I cant even click the scan option it is disabled. as you see on the screenshot.
PostPosted: March 2nd, 2010, 15:16
dont click on the assigned letter. Right click on the drive itself. So right click on HTS541080... etc, choose scan option.
PostPosted: March 2nd, 2010, 15:24
I like how the main drive is a Quantum Fireball
PostPosted: March 2nd, 2010, 18:00
the disk is showing as no capacity. either your usb connector is not working or the disk has a serious failure. Is the data important? if so stop what your doing now and get yourself a quote for data recovery. try pcimage on this forum.
PostPosted: March 4th, 2010, 19:57
Could we see the partition table and boot sector with Microsoft's Sector Inspector?
http://www.users.on.net/~fzabkar/SecInspect.zip
Extract the above archive to the one folder and execute the SIrun.bat file. The procedure will generate a report file named SIout.txt which you can then upload to a file sharing service so that we can examine it.
PostPosted: March 4th, 2010, 19:59
Thats like driving a Toyota over here...
PostPosted: March 4th, 2010, 23:14
hi,
does it will work for this case? any hopeful? or Toyota too?
data recovery service[/b]
PostPosted: March 5th, 2010, 0:04
hi,
The first thing to do when you suspect file system corruption is to survey the damage. The drive is showing up with a drive letter. This means that the OS is seeing the partition table, but perhaps it is corrupt, or perhaps the boot sector has been damaged.
PostPosted: March 5th, 2010, 11:09
I think you should not be accessing the HDD through USB. This will only add to your problems if the HDD is not entirely healthy or stable.
PostPosted: March 5th, 2010, 13:31
I had heard there was still one out there, but I thought it was a rumour ..
https://www.mjm.co.uk/
PostPosted: March 6th, 2010, 6:56
I dont know If ıt ıs useful for you but I did a secinspect file.
I am uploading it as you have said, ıt might be useful to diagnose..
File comment: Output of the Sec inspect..
SIout.txt [7.6 KiB]
Downloaded 623 times
PostPosted: March 6th, 2010, 6:58
the scan option also not available on the "HTS541080..."
so in both case disabled.
PostPosted: March 6th, 2010, 8:31
What does it show under WMI disk manager (Right click My Computer, select manage, then select disk drives)
PostPosted: March 7th, 2010, 5:28
The screenshot from WMI Services is like this.
Do you mean by right click or?
Users browsing this forum: Google [Bot] and 65 guests
