 Post subject: my hard drive shows 0.00MB
PostPosted: March 11th, 2010, 3:16
I have two hard drives a western Digital and a seagate both 160 GB they are showing 0.00 MB Capacity.Anyone who can offer any help?
 Post subject: Re: my hard drive shows 0.00MB
PostPosted: March 11th, 2010, 8:47
both together? have you try one by one?
data recovery service[/b]
PostPosted: March 11th, 2010, 14:55
Depending on the Seagate, could be a DIY if your careful, based on what I know I'm thinking the WD will require a pro, or expensive equipment and extensive knowledge.
What are the specs of the Seagate? Series, model, firmware, etc
PostPosted: March 12th, 2010, 0:56
U first diagnostics use MHDD or similar tool and check ATA registers. check if hdd´s are correctly detected, Model, SN, check answers to read sector commands and check ATA Control registers answers while tried to read sectors like IDNF or ABRT , At the WD Case its knowking and shows´0 bytes could be caused by a bad head too, from this answer u will know the problems and possible solutions if u dont know how to do it, u know the answer
Users browsing this forum: No registered users and 77 guests
