 Post subject: SEAGATE HARDDISK COMPONENT HELP NEEDED
PostPosted: March 11th, 2010, 8:03
Hi, I am new to this forum, I wonder if you could help me:
I have a Seagate 160Gb SATA ST3160211AS barracuda , and suddenly my harddisk power cable has been burned and the pinout also
S/N: 6PT1RXAA
ST3160211AS
P/N: 9CC112-302
Firmware : 3.AAE
Date code : 07195
Examining the Hard disk PCB (logical board) I have found a component has been burned
Here is the photo (the component is signaled in red, you may have to click the pictures to see them in full detail)
And so, the inevitable question of course is, does anyone knows what type of components they are? capacitors, resistors, diodes, voltage spike protectors, ... ? and do you know their values as well, so I can weld equivalent ones? Or at least do you know any schematic of this Seagate, because I searched the Net a LOT, and found nothing!
I have to recover my data.
Please, please, PLEASE, help.
Thanks in advance :)
 Post subject: Re: SEAGATE HARDDISK COMPONENT HELP NEEDED
PostPosted: March 11th, 2010, 12:37
Hint - Search function works wonders on here - TVS - you will find what you are looking for - it has been discuessed many times over and should produce the results you are looking for
Iorana Haraharaini
PostPosted: March 12th, 2010, 0:15
sorry, can u plz tell me the exact name of that diode
PostPosted: March 12th, 2010, 0:16
The name and everything else you need to know, follow this link:
http://tinyurl.com/yk3qhc4
PostPosted: March 13th, 2010, 19:37
TVS I told you what it was
Iorana Haraharaini
PostPosted: March 13th, 2010, 19:38
Iorana Haraharaini
PostPosted: March 13th, 2010, 19:44
remove it and see what happen :)
ZeBong
" Россия еще раз"
Users browsing this forum: No registered users and 82 guests
