RAID 0 Screw Up
March 16th, 2010, 0:43
I am all screwed up and it started with one drive and now all 4 drives i had plugged into my raid controller will not work. I found Easeus and used it to recover my files off both raid arrays. Ill start with the first and then the second
First Array
2x patriot memory WARP SSD 32gb RAID 0
One day came home and operating system was frooze so i hit the reset button an a blue screen of death would pop up everytime it tryed to boot. I tryed useing windows server backup but it wouldnt work. I then tryed to just format an reinstall but one of the disk will not format. I broke the array up and only one disk works the other is still seen and it says raw. I used easeus to recover the data but now i want to format it an use it as a seperate disk. I tryed going into bios to and deleteing the array but it pops right back up. Is there anyway to delete this or use this disk at all?
Second array
2x Samsung 1tb drives Raid 0
Basicly i unplugged them with the power off so i could plug my NEW OS drive in and the bad drives. (the OS was on the first array but went bad so i put it on a new one) When i plugged them back in the BIOS says healthy array but when i get into windows it doesn not show the drives. Any answer to why this is happening?
Thanks i hope this helps someone help me out thanks!
Marcus
