 Post subject: Maxtor 4D040H2 question
PostPosted: March 22nd, 2010, 18:04
Drive motor sounds like a jet engine and sounds like it may be varying in rpm but drive comes ready a bit slow and is identified with correct model, s/n and capacity but no access to any data sectors. All modules check good but it takes a long time to read them and they don't all read all of the time. Put platter in a drive with a good motor. Now it takes a while before heads calibrate but then it comes ready and reading the system modules is now stable. What is throwing me off is that the DMCS modules header is NO_DMCS. Can this be why I can not access the data area?
 Post subject: Re: Maxtor 4D040H2 question
PostPosted: March 22nd, 2010, 18:26
yes
This is a self-deactivation state.
If you fix the modules you will get user data access.
Janos
PostPosted: March 23rd, 2010, 12:49
Thanx Janos. I wrote the correct header into the DMCS modules, recalculated the CRC, reset drive and had data access. Got good image with only a couple of bad sectors.
PostPosted: March 23rd, 2010, 15:16
yw. ;)
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 83 guests
