 Post subject: Spinrite OMG
PostPosted: March 23rd, 2010, 11:53
Hi guys im very new to data recovery but ive been in IT for eons.... one of my co-workers ran spinrite on a clients notebook which hard drive was failing.... the hard drive now seems to work stellar but he cant find the outlook.pst file :S is there any way to reverse spinrite or get back this outlook.pst file?
 Post subject: Re: Spinrite OMG
PostPosted: March 23rd, 2010, 18:07
:lol:
PostPosted: March 23rd, 2010, 18:25
Assuming there is no surface problems give it a once over with r-studio (scan the disk) you may get lucky and find your file. Dont do this if the drive is clicking!
:Leigh
DataWreck Data Recovery Services
www.DataWreck.co.uk
PostPosted: March 23rd, 2010, 20:58
Datawreck
i think there was a surface problem, it had some bad sectors if that makes a difference... :(
PostPosted: March 24th, 2010, 4:14
Hello darkosski, Please read the spinrite wikipedia page as it gives good advice to amatuer data recovery technicians.
The heading 'Alternatives' may give good insight.
http://en.wikipedia.org/wiki/SpinRite
Zero Alpha: zeroalpha.com.au
PostPosted: March 24th, 2010, 4:20
Maybe the bads that spinrite has "solved".... contained data.
Results of the DIY. What now ?
PostPosted: March 25th, 2010, 10:51
thanks for the info guys.... and gals
PostPosted: March 25th, 2010, 14:34
That is why the Spinrite manual suggests backing up the data before running the program. Once a sector has been remapped, any data that it left behind is gone. You might get lucky with a full scan of the drive with R-Studio, but I would suggest mirroring the drive first.
As I tell my clients...before Spinrite is run...usually less than $500...after Spinrite is run...likely more than $1000, if recoverable at all.
PostPosted: March 25th, 2010, 17:53
I Agree 100% with luke(lcoughey).Image the drive first. Other than R-studio, GetDataBack by Runtime can stitch files back to the file system quite well. This is assuming you don't have software like DE at your disposal. Even then...
Leigh
www.DataWreck.co.uk
PostPosted: March 25th, 2010, 20:41
this is why you do a image of the drive first then use spinrite
i dont really use this for any recovery needs as i dont see how it can recovery in the help of your data
your find out that the data was on the bad sector
so it be bye bye data forever.
