 Post subject: slow imaging samsung sp0812c
PostPosted: March 27th, 2010, 21:07
hi all
i got this drive in for recovery, it has been elsewhere and not too sure of the history but drive has not been opened, i suspect it was simply done as a software recovery for as much as thye could get off the drive.
issue with drive is it will id on pc3000 and i cant access data, did a chead test and found head 1 to be faulty.
repalced heads, did a head test and heads 0 and 1 all good now.
drive will id correctly, however if i try and build an image of the drive it will take an extremely long time, so far 2 million blocks in 20 hours,
tired imaging on both pc 3000 and atola and same results.
if i try and do a read of data directly with DE i am getting lots of software and hardware resets along wih an intermittent slight click, and data cant be read.
hoping someone can provide a bit of info about this drive.
Thank you
 Post subject: Re: slow imaging samsung sp0812c
PostPosted: March 28th, 2010, 12:32
Wrong materials or... you need my tool :wink:
(Hope you understood !)
Best regards !
Users browsing this forum: Google [Bot] and 88 guests
