 Post subject: Help: need driver for CA-42 cable
PostPosted: April 4th, 2010, 9:10
Hi All,
Hope that this is the right place to ask.
I need the driver for the CA-42 cable (For the 7200.11 problem).
I bought this one
http://imshopping.rediff.com/shopping/p ... 025130.JPG
It come without any driver.
Can't find the driver anywhere.
Please give me link to the driver :)
Many Thanks!
 Post subject: Re: Help: need driver for CA-42 cable
PostPosted: April 4th, 2010, 11:17
I would say ask the shop where you purchased from... They should have the right driver if it requires one.
PostPosted: April 4th, 2010, 12:25
I've tried this but the seller on ebay does not respond to my mails..
Any suggestions?
PostPosted: April 4th, 2010, 15:57
I'm assuming this is an aftermarket cable rather than a genuine Nokia version. In any case, you should be able to determine the Product and Vendor IDs (PID / VID) using a utility such as Microsoft's UVCView:
http://www.users.on.net/~fzabkar/USB_ID ... ew.x86.exe
Post the report here. The PID and VID will hopefully identify the manufacturer of the USB-RS232 bridge chip inside the cable.
PostPosted: April 5th, 2010, 6:47
Thanks for the halp! :)
Those are the wanted lines:
idVendor: 0x067B = Prolific Technology, Inc.
idProduct: 0x2303
In a case that I published the wrong lines, this is full report:
---===>Device Information<===---
English product name: "USB-Serial Controller"
ConnectionStatus:
Current Config Value: 0x00 -> Device Bus Speed: Full
Device Address: 0x01
Open Pipes: 0
*!*ERROR: No open pipes!
===>Device Descriptor<===
bLength: 0x12
bDescriptorType: 0x01
bcdUSB: 0x0110
bDeviceClass: 0x00 -> This is an Interface Class Defined Device
bDeviceSubClass: 0x00
bDeviceProtocol: 0x00
bMaxPacketSize0: 0x40 = (64) Bytes
idProduct: 0x2303
bcdDevice: 0x0300
iManufacturer: 0x01
English (United States) "Prolific Technology Inc."
iProduct: 0x02
English (United States) "USB-Serial Controller"
iSerialNumber: 0x00
bNumConfigurations: 0x01
===>Configuration Descriptor<===
bLength: 0x09
bDescriptorType: 0x02
wTotalLength: 0x0027 -> Validated
bNumInterfaces: 0x01
bConfigurationValue: 0x01
iConfiguration: 0x00
bmAttributes: 0x80 -> Bus Powered
MaxPower: 0x32 = 100 mA
===>Interface Descriptor<===
bLength: 0x09
bDescriptorType: 0x04
bInterfaceNumber: 0x00
bAlternateSetting: 0x00
bNumEndpoints: 0x03
bInterfaceClass: 0xFF -> Vendor Specific Device
bInterfaceSubClass: 0x00
*!*CAUTION: This appears to be an invalid bInterfaceSubClass
bInterfaceProtocol: 0x00
iInterface: 0x00
*!*ERROR: 0xFF is the prerelease USB Video Class ID
===>Endpoint Descriptor<===
bLength: 0x07
bDescriptorType: 0x05
bEndpointAddress: 0x81 -> Direction: IN - EndpointID: 1
bmAttributes: 0x03 -> Interrupt Transfer Type
wMaxPacketSize: 0x000A = 0x0A bytes
bInterval: 0x01
bLength: 0x07
bEndpointAddress: 0x02 -> Direction: OUT - EndpointID: 2
bmAttributes: 0x02 -> Bulk Transfer Type
wMaxPacketSize: 0x0040 = 0x40 bytes
bInterval: 0x00
bLength: 0x07
bEndpointAddress: 0x83 -> Direction: IN - EndpointID: 3
bInterval: 0x00
PostPosted: April 5th, 2010, 16:34
idProduct: 0x2303
idProduct: 0x2303
bcdDevice: 0x0300
iManufacturer: 0x01
iProduct: 0x02
This looks promising:
http://www.prolific.com.tw/Eng/downloads.asp?ID=31
PL-2303 USB to Serial Bridge (H, HX, X) Installshield Driver Setup Program:
http://www.prolific.com.tw/support/file ... r_v110.zip
For Prolific USB VID_067B&PID_2303 Only
Users browsing this forum: Google [Bot] and 75 guests
