 Post subject: What are the common causes for faults in Hard drives?
PostPosted: April 4th, 2010, 17:03
Hi All,
What are the common causes for faults in hard drives?
Heads, PCB, ETC...
That question will help me to understand (at least to try..) the "Data Recovery World".
Many Thanks!
 Post subject: Re: What are the common causes for faults in Hard drives?
PostPosted: April 4th, 2010, 17:17
- Logical problems
- Mecanical problems
ZeBong
" Россия еще раз"
PostPosted: April 4th, 2010, 17:29
- Bad users
- Friends with internet connection
PostPosted: April 4th, 2010, 17:30
- Sunspots
- Neutrinos
- google, and try to understant this DR world.
ZeBong
" Россия еще раз"
PostPosted: April 4th, 2010, 17:57
- "computer scientist colleague" ;)
PostPosted: April 5th, 2010, 17:55
The manufacturers.
PostPosted: April 5th, 2010, 19:20
Russwinters wrote:
The manufacturers.
have to agree on this one the manufacturers are the problem
because produce a lot cheaper now.
and rush them out of the factory with out full soak test on the drive.
who are the worse in companys that make these drives.
me personel i think seagate is the worse now
1)spindle motor problems
2)firmware problems
3)headstack problems
PostPosted: April 5th, 2010, 19:45
I have to admit that I don't exactly hate the manufacturers; without them we would not be needed!
PostPosted: April 5th, 2010, 23:52
true like end of the day your going to use something everyday or you dont look after it
then its going to break down.
but some factory like seagate have gone downhill
the problem now is bigger the drive is it more likely going to fail
Users browsing this forum: Google [Bot] and 66 guests
