 Post subject: Cannot access smart and sensor data via esata?
PostPosted: April 6th, 2010, 13:51
Good day,people.
I think I could use some help determining what is wrong with the external HDD enclosure I got today.
It's a Verbatim esata & usb combo enclosure with a SAMSUNG HD103SI disk inside.
The problem is,I cannot acquire the smart data of the disk when it hooks up with my rig with esata.
I tried hddscan,hddtune,everest,hard disk sentinel but still no dice.
It also seems that alot of the features of the disk cannot be detected by the various softwares.
So,any pointer on what may be wrong with the disk.
Thank you.
P.S:
Below is the disk information readings from hard disk sentinel.
Hard Disk Summary
Hard Disk Number,2
Interface,S-ATA II
Disk Controller,Intel(R) ICH9 Family 4 Port SATA AHCI Controller - 2923 (AHCI)
Disk Location,"Channel 5, Target 0, Lun 0, Device: 0"
Hard Disk Model ID,SAMSUNG HD103SI
Firmware Revision,1AG01118
Total Size,953867 MB
Power State,Active
Logical Drive(s)
Logical Drive,H:
ATA Information
Hard Disk Cylinders,1938021
Hard Disk Heads,16
Hard Disk Sectors,63
Total Sectors,1953525168
ATA Revision,ATA/ATAPI-6 T13 1410D version 1
Bytes Per Sector,512
Multiple Sectors,1
Error Correction Bytes,0
Unformatted Capacity,953870 MB
Maximum PIO Mode,4
Active PIO Mode,0
Maximum Multiword DMA Mode,2
Maximum UDMA Mode,300 MB/s (6)
Active UDMA Mode,300 MB/s (0)
Minimum multiword DMA Transfer Time,120 ns
Recommended Multiword DMA Transfer Time,120 ns
Minimum PIO Transfer Time Without IORDY,120 ns
Minimum PIO Transfer Time With IORDY,120 ns
ATA Control Byte,Invalid
ATA Checksum Value,Invalid
Acoustic Management Configuration
Acoustic Management,Not supported
Acoustic Management,Disabled
Current Acoustic Level,Default (00h)
Recommended Acoustic Level,Default (00h)
ATA Features
Read Ahead Buffer,Not supported
DMA,Supported
Ultra DMA,Supported
S.M.A.R.T.,Supported
Power Management,Supported
Write Cache,Supported
Host Protected Area,Not supported
Advanced Power Management,Not supported
Power Up In Standby,Not supported
48-bit LBA Addressing,Supported
Device Configuration Overlay,Not supported
IORDY Support,Supported
Read/Write DMA Queue,Not supported
NOP Command,Not supported
Trusted Computing,Not supported
64-bit World Wide ID,Not supported
Streaming,Not supported
Media Card Pass Through,Not supported
General Purpose Logging,Not supported
Error Logging,Not supported
CFA Feature Set,Not supported
CFast Device,Not supported
Long Physical Sectors (1),Not supported
Long Logical Sectors,Not supported
Write-Read-Verify,Not supported
NV Cache Feature,Not supported
NV Cache Power Mode,Not supported
NV Cache Size,Not supported
Free-fall Control,Not supported
Free-fall Control Sensitivity,Not supported
SSD Features
Data Set Management,Not supported
TRIM Command,Not supported
Deterministic Read After TRIM,Not supported
S.M.A.R.T. Details
Off-line Data Collection Status,Never Started
Self Test Execution Status,Successfully Completed
Total Time To Complete Off-line Data Collection,0 seconds
Execute Off-line Immediate,Not supported
Abort/restart Off-line By Host,Not supported
Off-line Read Scanning,Not supported
Short Self-test,Not supported
Extended Self-test,Not supported
Conveyance Self-test,Not supported
Selective Self-Test,Not supported
Save Data Before/After Power Saving Mode,Not supported
Enable/Disable Attribute Autosave,Not supported
Error Logging Capability,Not supported
Security Mode
Security Mode,Not supported
Security Erase,Not supported
Security Erase Time,Not supported
Security Enhanced Erase Feature,Not supported
Security Enhanced Erase Time,Not supported
Security Enabled,No
Security Locked,No
Security Frozen,No
Security Counter Expired,No
Security Level,High
Serial ATA Features
S-ATA Compliance,Yes
S-ATA I Signaling Speed (1.5 Gps),Supported
S-ATA II Signaling Speed (3 Gps),Supported
S-ATA Gen3 Signaling Speed (6 Gps),Not supported
Receipt Of Power Management Requests From Host,Not supported
PHY Event Counters,Not supported
Non-Zero Buffer Offsets In DMA Setup FIS,Not supported
DMA Setup Auto-Activate Optimization,Not supported
Device Initiating Interface Power Management,Not supported
In-Order Data Delivery,Not supported
Asynchronous Notification,Not supported
Software Settings Preservation,Not supported
Native Command Queuing (NCQ),Supported
Queue Length,32
Disk Information
Disk Family,SpinPoint F2EG
Form Factor,"3.5"" "
Capacity,"1000 GB (1000 x 1,000,000,000 bytes)"
Number Of Disks,0
Number Of Heads,?
Rotational Speed,5400 RPM
Rotation Time,11.11 ms
Average Rotational Latency,5.56 ms
Disk Interface,Serial-ATA/300
Buffer-Host Max. Rate,300 MB/seconds
Buffer Size,32768 KB
Drive Ready Time (typical),11 seconds
Average Seek Time,8.9 ms
Track To Track Seek Time,? ms
Full Stroke Seek Time,? ms
Width,101.5 mm (4.0 inch)
Depth,147.0 mm (5.8 inch)
Height,26.1 mm (1.0 inch)
Weight,610 grams (1.3 pounds)
Acoustic (Idle),2.7 Bel
Acoustic (Min performance and volume),2.8 Bel
Acoustic (Max performance and volume),2.8 Bel
Required power for spinup,"2,250 mA"
Power required (seek),9.5 W
Power required (idle),7.7 W
Power required (standby),0.9 W
Manufacturer,Samsung
Manufacturer Website,http://www.samsung.com/Products/HardDiskDrive/index.htm
Users browsing this forum: Google [Bot] and 68 guests
