 Post subject: wd head and pcb hellp need
PostPosted: April 6th, 2010, 15:40
Hello ,
I need your advice for the following situation
1. hdd for recovery data:
Hdd Western Digital 1600JB-00REA0
DATE 14.JAN 2006
DCM:HSCHCTJCA
PCB number:2060-701292-Rev A
2.HDD Donor:
WD2000JB-00GVA0
DATE 16.12.2004
DCM:HSBCTJAH
PCB number2060-001265-001 REV A
I want to follow the following procedure:
swap rom from pcb hdd 1 to pcb hdd 2
change defective head (hdd 1) ,transplant head from hdd 2 to hdd 1
Final
I have practically with defective HDD(hdd1), electronics and functional heads of the donor HDD(hdd 2)
Both models have 6 heads
It is possible to have success in this proceeding or how we should proceed?????
Thanks in advance
 Post subject: Re: wd head and pcb hellp need
PostPosted: April 6th, 2010, 16:25
do you have experience in change heads ? aligment etc...
the sucess is better you contact a DR company for that, and not all DR companys can do that work.
ZeBong
" Россия еще раз"
PostPosted: April 6th, 2010, 16:29
These 2 drives are not compatible, additionally you need to fight with the WD head alignment problem...
I suggest to find a company who can handle the alignment problem, before you open the patient drive.
Janos
PostPosted: April 6th, 2010, 20:12
why you don't take Samsung or Seagate 160Gb for donor drive? even 2.5"
data recovery service[/b]
PostPosted: April 6th, 2010, 21:49
One more thing both models donot have 6 heads .
PostPosted: April 7th, 2010, 2:19
:lol: :lol:
PostPosted: April 7th, 2010, 5:08
Spare heads are available :D
PostPosted: April 7th, 2010, 11:25
You make the rules of compatibility recovery for heads, head map, DCM preamp,
then I will make this experiment. :twisted:
Many Thanks!
PostPosted: April 7th, 2010, 14:17
@steven1979,
will you still go for the head change ?
Users browsing this forum: No registered users and 92 guests
