 Post subject: Samsung HS122JF - Where is the transient voltage suppresor?
PostPosted: April 7th, 2010, 17:16
I have a Samsung HS122JF that on my Deepspar comes un with a BSY, DSY, DSC and UNC, I went through and checked the chip I thought might be the TVS and when I use the voltameter to check it there is no continuity. The chip is the wAN7, can anybody confirm this chip as the TVS?
Thank you..
 Post subject: Re: Samsung HS122JF - Where is the transient voltage suppresor?
PostPosted: April 7th, 2010, 17:23
What about thru a normal power supply, does the drive spin?
Data Recovery Ireland
PostPosted: April 7th, 2010, 17:33
Does it have a polarity stripe?
Is it connected across the supply?
Can we see a detailed photo?
PostPosted: April 7th, 2010, 18:32
I connected straight to the power supply bypassing the deepspar, but same... You want a detailed photo? The pcb board? I will load it up... This drive is extremely difficult to detect if it´s spinning, I think I will need a stethoscope...
PostPosted: April 7th, 2010, 18:39
Try your ear :)
PostPosted: April 7th, 2010, 21:20
If you're using a half decent power supply, connecting a drive with a blown TVS should cause it to shut off
PostPosted: April 7th, 2010, 21:33
The OP said the component measured open. It's an unlikely failure mode for a TVS diode, but not impossible.
PostPosted: April 8th, 2010, 8:51
Photo of PCB, the circled chip is the chip that does not show continuity. Is this the TVS?
PostPosted: April 8th, 2010, 9:34
CK wrote:
Try your ear :)
Turned everything off, tried the ear theory, don´t hear anything..
PostPosted: April 8th, 2010, 9:39
Try to connect other similar PCB if drive spins it means your PCB has Problem if same condition "Head stuck in side" u have to open and see.
PostPosted: April 8th, 2010, 10:22
Unfortunately I don´t have a similar board, but how about the chip that has no continuity?
PostPosted: April 8th, 2010, 10:27
If it is open, how has it failed in a way that will affect the circuit?
PostPosted: April 8th, 2010, 10:34
The drive is not spinning up, I think that it could be a fuse (TVS Diode) which needs to be removed, so that the drive can spin up? The laptop was working, got moved to a location near by and presto the drive would not come up..
PostPosted: April 8th, 2010, 12:49
Now generally the fuse is on the side where the power connects to the PCB, but in this case the only chip without any continuity is on the other side of the pcb board..
PostPosted: April 8th, 2010, 13:31
Ray Charles and Stevie Wonder are back to back on a dark street... "Hi, Ray !" "Hi, Stevie !"
PostPosted: April 8th, 2010, 19:26
It won't affect the circuit, but it will give an indication as to what killed the drive.
In any case, the OP was asking for help in identifying the component, whatever it is.
PostPosted: April 8th, 2010, 19:48
The photo is not very clear, but there appear to be two components with that same marking. Therefore I doubt that either is a TVS diode, at least not ones that are connected across the supply.
Does the other part measure open as well? What are those two horizontal devices directly below? AFAICT, they seem to be associated with the spindle motor circuit.
PostPosted: April 8th, 2010, 21:12
I suspect that there are actually four "wAN7" components, not two. I'm wondering whether they constitute a full wave bridge rectifier to derive emergency retract power from the motor windings after power loss.
PostPosted: April 8th, 2010, 21:29
Correct there are 4, but only 1 does not show continuity.. The one circle in red shows not continuity..
PostPosted: April 8th, 2010, 22:06
Perhaps you have a stiction issue. Maybe an unsuccessful emergency retract left the heads on the platter(s)???
Users browsing this forum: No registered users and 172 guests
