 Post subject: WD5000AAKS PCB
PostPosted: April 9th, 2010, 6:10
I have received several WD5000AAKS drives which PCB's doesn't match the HDA's. The previous owner apparently has tried PCB swap.
For the older WD drives the PCB serial number was written in a firmware module. Is it the same with the current models? If yes, which module I should look at?
 Post subject: Re: WD5000AAKS PCB
PostPosted: April 9th, 2010, 7:31
are you sure?
which model/s you have in mind?
www.datarecoveryne.com
PostPosted: April 9th, 2010, 7:45
harddrivespecialist wrote:
are you sure?
Oops, it was with Maxtor drives. Sorry.
PostPosted: April 11th, 2010, 5:50
02
Sorry, I didn't read the sentence very well.
PostPosted: April 11th, 2010, 19:44
maxtors??? WD5000AAKS???
data recovery service[/b]
PostPosted: April 13th, 2010, 4:41
Let's try another question.
Assuming I could read both Flash and SA modules.
Which module should match Flash content if the PCB is the original?
PostPosted: April 13th, 2010, 7:18
Portions of many modules contains flash info.
PostPosted: April 13th, 2010, 8:02
OK. Which portion of flash info is unique for each drive and which module contains this portion?
PostPosted: April 13th, 2010, 9:19
You don't have that many choices
Users browsing this forum: No registered users and 247 guests
