 Post subject: Seagate Barracuda 7200.10 500G burned out
PostPosted: April 9th, 2010, 8:50
Hello everyone, I am lucky to find this forum. I got an emergency here because my drive is fried due to a power supply. Now everytime I plug in my Barracuda it short out the power supply. I have to unplug the power supply in order to boot the machine.
I read the TVS diode might be bad, I just want to double check to see if that is the case. I attached 2 pics for review and circled 2 components that I think TVS diodle.
Should I test it before de-soldered? I don't want to break anything more. Thanks.
 Post subject: Re: Seagate Barracuda 7200.10 500G burned out
PostPosted: April 9th, 2010, 12:32
You are right on both cases. Use volt meter and test then remove
Iorana Haraharaini
PostPosted: April 9th, 2010, 14:09
Thank you for the feedback... I will pray for everything to work.
Users browsing this forum: Google [Bot] and 260 guests
