 Post subject: WD3200BMVV-11A1PS0
PostPosted: April 14th, 2010, 3:39
Hello gurus,
Anyone got FW for this drive :
WD3200BMVV-11A1PS0
01.01A01
Thank you
 Post subject: Re: WD3200BMVV-11A1PS0
PostPosted: April 14th, 2010, 6:02
hi,
i have same model of this drive. no sure FW version. 8)
data recovery service[/b]
PostPosted: April 14th, 2010, 6:46
Thank you networkpc3000 for checking.
I want the FW only, not the entire disk.
PostPosted: April 14th, 2010, 6:58
Thank you friends,
Problem solved.
PostPosted: December 8th, 2010, 17:33
Hi
I have the same drive and I have a problem!
The drive showing 0KB, and it starts up, motor spins, and then 1 Click and then noise, and then motor spins down..
I cannot format it, nor read it?
What to do?
PostPosted: December 8th, 2010, 20:11
bayanati wrote:
Hi
What to do?
Two choices on this one. Seems you do nto want data if you want to format it. Check to see if you can RAM the drive or buy a new one that is not WD.
Iorana Haraharaini
PostPosted: December 9th, 2010, 10:45
Of course I want the data.. I am just describing the situation. If i can format it.. I can recover it..
ANY ONE have better ideas?
regards
PostPosted: December 9th, 2010, 12:43
regards
Yes data can be recovered but not by DIY means which means you will not be able to do this one on your own. This on a lot of WD drives is head issue where 0MB shows up, drive click, spins up and stops. The drive can not read readiness and is stuck from head isues. So like I said your options are 1. check to see if you can RMA the HDD, 2. Buy a new HDD that is not WD, 3. Take it in to a DR shop for them to give you an estimate on it. 4. Ask if anyone here is in your area and we can have you send the drive to them. But head swap on WD require tool, a good working knowledge of this drive, and a lot of knowledge on how to align the heads after they have been changed out. Tools meaning people have to invest at least for starters on this one around 10.000 + dollars. These tools allow us to work in a reserved area on the drive called the service area to see if anything in the start up of the drive is damaged or broken, it allows us to work with heads and all kinds of other issues. Knowledge meand years of research and working with these drives to understand how they operate and to be able to fix them and get off data. So now the choice is yours on this one.
Iorana Haraharaini
PostPosted: December 9th, 2010, 16:33
If the idea is DIY it's game over, to me, unless you have the proper tools. There's little to do.
PostPosted: December 11th, 2010, 11:56
I have SalvationData tools, but its been only 1 month for me now..
Can it be done??
PostPosted: December 11th, 2010, 13:19
In a nutshell you have the tool (SD) but don't know how to use it or you are unable to pinpoint your specific problem? P.s. Start another thread instead of attaching to existing one, to avoid confusion...
Users browsing this forum: No registered users and 122 guests
