 Post subject: PCB Needed For Seagate 320 GB 5400.5
PostPosted: April 16th, 2010, 18:53
I'm looking to find a PCB to replace my hard drive. Here are the specs. Someone please help
Seagate 320
Momentus 5400.5
Date: 09232
Site: WU
ST9320320AS
PN: 9EV134-500
FW: SD03
 Post subject: Re: PCB Needed For Seagate 320 GB 5400.5
PostPosted: April 17th, 2010, 23:20
hi,
i can help. would you like to post high quality images of your PCB both side? thanks.
data recovery service[/b]
PostPosted: April 21st, 2010, 2:35
See pictures attached.
File comment: Notice discoloration of the last four gold pieces.
PostPosted: April 23rd, 2010, 4:03
The board appears to have a shorted TVS diode. If your PSU is OK, then you can remove this diode by desoldering it, or by snipping it out with flush cutters. The drive will work OK without it, but it will no longer have any protection from overvoltages.
I can't see on the photo, but sometimes there are resistors or fuses in series with the supply. If these are open circuit, then just bridge them with a short piece of wire, or replace them with a 2A picofuse.
PostPosted: April 23rd, 2010, 4:07
Isnt it worth even considering what actually caused the damage, and more to the point if it will cause further problems running a disk with potentially damaged components such as preamp chip without any kind of protection on the PCB?
PostPosted: April 23rd, 2010, 4:40
I said "if your PSU is OK ...".
PostPosted: April 23rd, 2010, 4:41
Sorry Frank, I did not realise that a good PSU is a good solution for a bad preamp... :lol:
PostPosted: April 23rd, 2010, 5:11
Looks the main bga chip has burned :?
PostPosted: April 23rd, 2010, 9:09
Nah, I think that mark is just a bit of the rubber from the pad that protects the PCB from the HDA.
But there is a reason WHY the TVS blew, so just snipping it off isn't ideal.
PostPosted: April 23rd, 2010, 11:50
Oooops :oops:
PostPosted: April 23rd, 2010, 22:18
You wrote "Isnt it worth even considering what actually caused the damage, and more to the point if it will cause further problems running a disk with potentially damaged components such as preamp chip without any kind of protection on the PCB?"
The damage was obviously caused by an overvoltage, ie an external event. The blown TVS diode is ample evidence of that. Or are you suggesting that some mysterious event on the PCB caused it to destroy its own protection diode?
A TVS diode is normally open circuit, so its presence, or absence, will have absolutely no effect on any vulnerable component, provided that the drive is connected to a good PSU. If some component subsequently fails after being supplied with its rated voltage, then that's just too bad.
In any case, a replacement TVS diode can be purchased for about $1 from Farnell, Mouser, Digikey.
PostPosted: April 28th, 2010, 6:04
connecting two legs I think it is a complete
VERY HAPPY Email WITH ME: khoiphucdulieu@yahoo.com
Users browsing this forum: No registered users and 90 guests
