 Post subject: wd 160g head matching
PostPosted: April 24th, 2010, 15:18
Hi
I have hdd WD1600AABS-00L8A0 DCM :DGRNHTJCH (bad hdd)
Donor hdd WD1600AABS-22L7A0 DCM :DGRNHTJCG
My question is : Is the donor head can match the bad hdd to replace it.
Note :Firmware is different
Thank you
 Post subject: Re: wd 160g head matching
PostPosted: April 24th, 2010, 16:46
Should be fine I think. However it does not mean that the drive would work after the transplant.
PostPosted: April 25th, 2010, 4:35
Thank u Pepe
If the drive not work after transplant what you think the resoans ?
PostPosted: April 26th, 2010, 15:41
I think what he is trying to say is that it might not be the heads that is the problem, or not just the heads. So be prepared to tackle other issues.
PostPosted: April 26th, 2010, 21:00
hi Pepe,
are you sure? as my experience: i don't think so. would you like to share your
data recovery service[/b]
PostPosted: April 26th, 2010, 23:07
What led you to conclude that the heads were bad?
http://www.datasaversllc.com
PostPosted: April 27th, 2010, 3:04
Pepe is correct (as usual).
The heads are compatible, but there's a very good chance the drive won't work with them without some "jiggery pokery".
PostPosted: April 27th, 2010, 3:13
Agree with Mr.Pepe, Mr.Jono and Mr.Sean
It's ONE head drive, then I think the transplant process should be easy enough. Sure until the head is the ONLY problem.
PostPosted: April 27th, 2010, 4:46
:oops: I did not consider it might be a one head drive... Then the chances are better of course.
PostPosted: April 27th, 2010, 10:03
its a 1 headed drive but prepare for a surprise. The head on a patiend is head 0? Donor can come with head 1 only. To save time consider ordering fullsized 320.
Users browsing this forum: No registered users and 78 guests
