 Post subject: Seagate P/N 9BX154-568 with firmware SD81
PostPosted: April 30th, 2010, 12:34
I have a HD by Seagate P/N 9BX154-568 with firmware SD81. It was over powered with a 19 volt power supply. I ordered a Seagate P/N 9BX154-303 with firmware SD1A and swapped the boards. I could hear the 9BX154-568 HD spinning but my computer would not recognize it. I am guessing it is because the firmware is different. I guess I need the same exact HD with the same firmware to make it work. Does anyone have any ideas or where I can find one with the same firmware?
 Post subject: Re: Seagate P/N 9BX154-568 with firmware SD81
PostPosted: April 30th, 2010, 13:52
That's a 7200.11 series, direct PCB swap is not possible due to adaptive ROM
CDR - Manchester Data Recovery Services
0161 408 4857
http://www.cheadledatarecovery.co.uk/
PostPosted: April 30th, 2010, 14:15
John is correct, the PCB's (or more precisely the info in the ROM) are ABSOLUTELY unique on this series.
PostPosted: April 30th, 2010, 19:52
here is demo video show you how to replace ROM chip from old PCB to good one.
http://www.youtube.com/watch?v=X2hgiDHiXKM good luck!
data recovery service[/b]
PostPosted: May 2nd, 2010, 1:30
Rather than replace the board, locate the 12V TVS diode on the original board. It will most likely be shorted.
Does your board look like this one?
http://img220.imageshack.us/img220/5310/dsc2495yt8.jpg
The photo shows a burnt 5V TVS diode near the SATA power connector. Your PCB will have a shorted diode to the right of it, near the edge of the board.
If you can trust your PSU, then remove the 12V diode with flush cutters. Your drive will work OK without it, but it will no longer have overvoltage protection on the +12V supply.
For continued protection, you can replace the diode with an SMBJ12A from Farnell, Mouser, Digikey.
Users browsing this forum: Google [Bot] and 90 guests
