 Post subject: An Old Conner HD
PostPosted: May 8th, 2010, 20:17
We have an old Conner HD and it has been Password locked. Anyone have any ideas on how to remove the password so we can access it.
We have not seen a Conner drive in years. It brings back memories. But, never seen one password locked.
Regards,
 Post subject: Re: An Old Conner HD
PostPosted: May 8th, 2010, 21:15
havent seen password on these drives also i would check pcb if were you .
PostPosted: May 9th, 2010, 7:40
It's (probably) one of the cheap Conner/Seagate transition drives. Like an ST31276A. Which case it does have a diag terminal
http://www.techbit.cz/files/obrazky/muz ... 76A_01.jpg
PostPosted: May 9th, 2010, 14:25
No it does not it is a CF210A using a diagnostic program it says it's password protected. I will look for a PCBA for the drive.
PostPosted: May 9th, 2010, 14:55
Don't think it's the PCB (very small chances, but it's worth a try). In any case if it is a CFS series I can do something (but have to send the drive).
PostPosted: May 10th, 2010, 13:18
I have never seen a CFS210A locked by a password before. Only 2.5" Conners.
Do you want the data or just unlock+erase the drive?
PostPosted: May 10th, 2010, 22:52
Let me try a PCB.
PostPosted: May 13th, 2010, 18:57
did it even support ATA password as per specification?, maybe is a disk encryption type ?
 Post subject: Re: An Old Conner HD - Update (Solved)
PostPosted: May 17th, 2010, 18:12
It was not locked. It's an older drive that works on the CHS addressing not LBA. So all my tools were telling me it was locked. I figured this out as I got a duplicate working drive hooked up and it said the same thing.
Drive has been cloned to a file and data has been recovered.
PostPosted: May 18th, 2010, 0:15
Excellent , good job :D
PostPosted: October 15th, 2015, 17:19
Reviving a really old thread.....
Received one of these in for recovery (a CP3204F) which does identify, but with 0 capacity and password protected (high). Not sure if changing a PCB on this old boy would help or not. Any advice?
PostPosted: October 17th, 2015, 16:01
Ended up using Linux and copied everything 100%.
Users browsing this forum: No registered users and 37 guests
