 Post subject: Momentus 5400.2, is the SA on the inside or outside?
PostPosted: May 11th, 2010, 20:38
I have a Model ST9120821AS with a small scratch on the inside of the platters. Is the SA on the inside?
Thanks, Ben
 Post subject: Re: Momentus 5400.2, is the SA on the inside or outside?
PostPosted: May 12th, 2010, 4:05
I believe SA is near the centre of platter on this one, but on surface you cannot see (bottom).
PostPosted: May 12th, 2010, 14:50
As far as i know, seagate have SA on the middle of the platter usually....
PostPosted: May 12th, 2010, 17:54
I would check for damaged at another surfaces too
PostPosted: May 12th, 2010, 18:24
I believe ~middle of H0 platter (or bottom most active head)
PostPosted: May 14th, 2010, 17:53
I guess I will try, Thanks
Users browsing this forum: Google [Bot] and 39 guests
