 Post subject: HDD SMART Failure
PostPosted: May 24th, 2010, 0:50
I have Samsung HDD, when I boot up my PC it detects my harddrive but it shows S.M.A.R.T. function failed. I tried connecting my harddrive to another pc to take copy of data it shows various partitions but while accessing those drives it says the drive is not formatted, do you want to formaat now?
What should I do to retrieve my data back?
 Post subject: Re: HDD SMART Failure
PostPosted: May 24th, 2010, 1:03
Most likely you have bad sectors in your drive or some serious damage and your drive needs an intervention by a professional to retrieve your data.
Seek for a pro in your country.
PostPosted: May 24th, 2010, 12:31
SMART failed and difficulties reading data + SAMSUNG drive = some kind of pro intervention is needed....
PostPosted: May 25th, 2010, 5:37
You can confirm a problem with bad sectors by running a SMART diagnostic.
Look for reallocated, pending, or uncorrectable sectors.
HD Sentinel (DOS / Windows / Linux):
http://www.hdsentinel.com/
HDDScan for Windows:
http://hddscan.com/
See this article for SMART info:
http://en.wikipedia.org/wiki/S.M.A.R.T
PostPosted: May 25th, 2010, 5:44
I think he needs his data Mr.Franc.
PostPosted: May 25th, 2010, 6:32
Thanxs for your replies guys
can u suggest some good tool that can recover data from disk suffering from SMART failure
PostPosted: May 25th, 2010, 7:03
I didn't mean to suggest that the OP should run the long DST. I was merely asking for a comprehensive SMART report. That shouldn't take more than a few minutes.
PostPosted: May 25th, 2010, 7:12
More tests on failing drive = weak heads that die completely OR some skiplist get full and then GAME OVER. :mrgreen:
Users browsing this forum: shubhsinghal and 63 guests
