 Post subject: HELP seagate ST3160212SCE
PostPosted: May 25th, 2010, 0:35
i accidentally erased the firmware on this drive. i could not find the firmware online. anybody can help recovering the firmware?
 Post subject: Re: HELP seagate ST3160212SCE
PostPosted: May 25th, 2010, 1:41
How did you manage to ERASE THE FIRMWARE (moreover : ACCIDENTALLY) ? :shock:
In any case if you destroyed ROM maybe "something" is possible (but not what you think i.e. brutally copy another ROM : this is exactly why simply swapping a PCB won't work).
If you erased completely the FW part on the platters, forget data.
An attempt is possible with 60-70% (rebuilding all) but it's gonna cost you a lot of money and there's no implicit guarantee about getting all data back.
Finally I can make the drive work again (rebuild all , will destroy everything on drive) but you have to send me the drive so it's not convenient.
PostPosted: May 25th, 2010, 9:16
What?
PostPosted: May 26th, 2010, 1:25
LOL... i was actually messing with firmware on another device while i had the drive connected to my pc, and accidentally switched the port to the one where the drive was. Maybe it wasnt a smart idea to decide to play with firmwares after 16 hrs of work and no sleep for 36hrs
PostPosted: May 26th, 2010, 1:42
Ehm... no.
Now you have 3 options :
- Pay a lot of ca$h (not a lot, a BIG lot) to have the drive fixed and data back (and it's not sure it will be possible).
- Write a fresh FW and use the factory procedures to "fix" the drive and use it again, but forget data.
- Use the drive as spare parts.
