 Post subject: Barracuda 7200.7 spin up problems
PostPosted: May 23rd, 2010, 12:31
hi,
this is my first post in this forum. i have a barracuda 7200.7, 80gb ide hard disk. the problem started after installing this hard disk in a new cpu, at first it wasn't coming up when i connected the ide cable to both this hard disk and the dvd drive, after a few tries it completely stopped, now whenever i start the computer, this hard disk makes a clanking noise and slows down the boot up and it never comes up in windows. please help me.
thank you
 Post subject: Re: Barracuda 7200.7 spin up problems
PostPosted: May 23rd, 2010, 12:58
Almost certainly physical head problems. If you need data then seek pro advice, if not then bin the drive. Simples
PostPosted: May 23rd, 2010, 18:41
hi,
have check it on others PC? sometimes this family hard drive have similar problem when power supply no enough or connector loose. hard drive repeat trying to start. perhaps got crash head if still no work.
data recovery service[/b]
PostPosted: May 23rd, 2010, 21:55
Check the jumpers first though.
Zero Alpha: zeroalpha.com.au
PostPosted: May 26th, 2010, 11:32
thanks for replying. can anyone explain to me what a physical head is.
Users browsing this forum: Google [Bot] and 106 guests
