 Post subject: ST9500420AS
PostPosted: May 28th, 2010, 11:04
Hi to all!!
this HDD very slow to get ready, strange sounds while trying to read the data, are apparently many bad blocks with reollocated very high, but when trying to test the route heads F3 ERROR LED=> LED:000000CE FAddr:00263339 I think that command should be not compatible.
It also found that these modules are bads. BAD MODULES
0E
2F
22
Question: This problem of reading the hds are really bads blocks or problems with the modules? Or finally the heads? => I do not believe that is still bad heads
Any help would be appreciated ...
Нет ничего невозможного
 Post subject: Re: ST9500420AS
PostPosted: May 29th, 2010, 1:58
perhaps got weak head. Seagate many drive got this kind of problem
data recovery service[/b]
PostPosted: June 27th, 2010, 3:46
I too ave ST3500820 AS with SD81 firmware showing the same malfunction. After SMART and GLIST erase, once the m0,.. command is given, he drive starts doing rebuild but gives LED:000000CE FAddr"28F5C7. See below output
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 00, Max Certify Rewr
ite Retries = 0000
User Partition Format 5% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 000
00080, Elapsed Time 0 mins 05 secs
LED:000000CE FAddr:0028F5C7
Any advice?
Thanks in advance
PostPosted: June 27th, 2010, 3:55
ST95XX=different from 3xxx. And VERY DIFFERENT PROBLEMS.
PostPosted: June 27th, 2010, 4:17
Yepp. True. But I thought the same error LED:000000CE could be of help to me as well.
PostPosted: June 27th, 2010, 6:37
Apply random solutions from the internet without proper diagnose = FUBAR.
PostPosted: June 27th, 2010, 6:44
HI,
This drive is giving the same error message in UDMA when tried to fix, as well as manual method through Hyper Terminal.
True that I posted under another model, but problem is 7200.11 - 0GB failure but LED:000000CE
Any idea?
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 55 guests
