 Post subject: Downgrade firmware MX1A to MX15
PostPosted: June 1st, 2010, 8:58
Hi, i have on Seagate 7200.11 with firmware problems. I can't to repair this, actually have firmware MX1A, but i can't to repair the size (465GB). I need to know if there is any way to downgrade to firmware MX15.
Thanks!!
 Post subject: Re: Downgrade firmware MX1A to MX15
PostPosted: June 1st, 2010, 9:19
for what reason would you do so?
PostPosted: June 1st, 2010, 9:27
I have problems with this hdd. I try to repair with pc3000, in automatic mode always return error, in manual mode, with terminal and commands, sometimes i can to repair but after with Data Extractor i can't to acces to hdd, it keep reading LBA 1. If i power off, in the next time, It does not support the size, is very strange case......
PostPosted: June 1st, 2010, 13:21
Try reading the new F3 Seagate manual that is in your box. This can help you fix this one look in appendix of the book. You will find your answer in there
Iorana Haraharaini
PostPosted: June 1st, 2010, 18:11
What's the bet it's a legal PC3K?? :o
Data Recovery Ireland
PostPosted: June 2nd, 2010, 0:24
or we can change another way: does your tools support it?
data recovery service[/b]
Users browsing this forum: Google [Bot] and 205 guests
