 Post subject: Seagate Barracuda 7200.11 clicking sound
PostPosted: June 2nd, 2010, 16:06
Hello!
I have a Seagate Barracuda 500GB which I wanted to recover from a friend. You all know the story : powered down the PC then no HDD in BIOS. Went to the good 'ol RS232 to USB converter but I get a DETSEC error, namely :
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 0.141 msecs
F3 2>U
Error 1009 DETSEC 00006008
Spin Error
Elapsed Time 26.717 secs
R/W Status 2 R/W Error 84150180
F3 2>/1
F3 1>N1
Unable to load Diag Overlay
When trying to spin-up it clicks a couple of time (no major noise) then remains spun. Also, if I use it as a normal drive, without the RS232, it doesn't click (but no BIOS detection either). I have been to "The Sollution for Seagate 7200.11 drives" on the MSFN Forum boards and also to Mr. Carters quite extensive and detailed site http://www.mapleleafmountain.com/seagatebrick.html to no avail. I have scraped clean all of the contacts but the issue persists.
So am I to understand that the drive has a mechanical failure?
 Post subject: Re: Seagate Barracuda 7200.11 clicking sound
PostPosted: June 2nd, 2010, 17:52
Eh, never mind... I thought that I might be able to free the heads from the jammed position by giving it a few bumps but it turns out that built quality on the .11 series is so good that one of the platters was dislodged. 300G shock-proof while offline (yeah, right). So, now I'm certain : it's mechanical!
Someone please close the thread. Thanks anyways, guys!
Love&Peace!
PostPosted: June 3rd, 2010, 13:45
Just curious : you discovered one platter was dislodged BEFORE "bumping" or "AFTER" ? I suspect that the drive originally suffered from shock.
PostPosted: June 6th, 2010, 5:55
just wish i had seen your post BEFORE you decided to get physical.
potentially has 1 command wrong that may actually stop you recovering the device correctly.
The double "click" is correct for this model.
Universal Declaration of Human Rights: Article 19
Users browsing this forum: No registered users and 208 guests
